Hey all, our house came with a flagpole installed in the front lawn, which is constructed of a handful of slip-fit aluminum tubes. The base tube section sheared off at the edge of the swedge/ diameter reduction. The result is a tube section that is one continuous diameter, with no swaged/reduced diameter to slip-fit into the bottom of the next section.
I’m wondering if there’s a way to swage the tube back to the correct diameter, just a few inches shorter. In theory I could TIG weld the sheared off piece back on (though I’m not much of a welder) but have since lost it.
Open to any suggestions on how to get the existing tube section back into service, and avoid buying a new $50-80 section ![]()
Thanks in advance!
