Vivi Bear’s nose got stuck in a zipper! How do we fix- is this home/makerspace fixable?
If you get some thread of the same color, and a long-ish needle, you should be able to put in some similar stitches to get the nose stable again. Just follow the same stitch pattern of big long stitches vertically. Imbed the knot somewhere inside the broken area, and then aim to hide the finishing knot along the side
I think hand sewing with a curved needle would probably do the trick. You could trim away the existing thread (or just the loose ones) and then make a pass over it with a similar looking thread.
I would probably leave the stitches and go overtop, and just trim away the thread that is too long
