Hi, normally I use an angle grinder to cut/grind metal, but I have a tight space I’m working with and don’t know the right tool for the job, or if asmbly has the tool.
Discourse says I can’t embed media items in a post nor can I put links in my post… I did the new member orientation yesterday so haven’t gotten permissions yet.
I need to cut off these nuts and grind the surface flat enough for me to put in a flat, reinforcing plate that won’t cave in like how my steel tubing did.
So far, the best I’ve found online is a die grinder.
Do we have one of those?
An oscillating multi-tool with the right cutter should work. They also have sanding attachments that could do the final clean up work. I have no idea if we have one in the shop though.
You could use a pneumatic chisel with a sharp end to knock them off. Then use a good metal file to clean the rough stuff before going to some kind of sand paper. No safety squints. Safety glasses and hearing protection if you go this route.
Update: The “detail” belt sander worked awesome! I was able to find this cheapo one on amazon for $36 and some blue sanding belts for $15. It was a little slow and I busted quite a few belts learning how to use the tool, but for the price I am satisfied. The space requirement was pretty tight so this worked great. Thanks @David78737
