I have a pair of 500lb heavy duty drawer slides. All the examples that I’ve seen use a butt joint to attach the plywood bottom of the drawer to vertical plywood sides, but it seems unlikely that plywood screwed up into plywood would be strong enough to make use of the 500lb capacity of the slides - I expect it would take much less tension force applied to the bottom would rip the screws through the core of the vertical pieces.
Here’s an example: https://youtu.be/1Qc9BmZf5W8?si=cJWH3CgXI4PoI_lm&t=375
and another: https://youtu.be/veAFhB5UQds?si=nJoUcLloNA4_ssBE&t=227
A few alternatives I’ve considered are banding the plywood bottom with a 90* metal bracket, wrapping the plywood bottom with a dadoed hardwood frame, and building a hardwood frame under the drawer slides.
The dimensions of the drawer will be about 70"Lx20"W
Any thoughts are appreciated.
