If the blade looks like this Please Post so we know to replace it. I only found out because someone texted me about it. Also slow down your down feed speed during the cuts and use the time during the cut to do something else. Teeth get trashed more quickly when we don’t use coolant and cut too quickly. The saw is made to work while you are working. It is a labor multiplier.
I forgot to ask about the coolant feed tank. The saw just bleeds out onto the floor after adding just a few ounces of water/coolant. I figure the tank must be full of sediment, but have not had the time to investigate.
