So the scope we had only.supported 3 out of 4 channels. It now does 4 with a little repair. I also added a VirtualBench which is a 4 channel scope to 500mhz BW and a 34 channel 1 GS/s logic analyzer and VPS with 25 volt plus and minus at 1A. And a VPS with 6 V 3 A. The dmm is a 5 1/2 digit, so no slouch with the capability of measuring 10 A and 300 VDC. Also a 200 MS/s update rate per second arbitrary wave generator. And some GPIO that can even do i2c. This workhouse has it all. I also brought in some early PXI RF workhorses that should be able to get some juices flowing. As far as electronics I want to put the hack back in hacker space. Let me know what other things would help with that. I have a library of things to pull from. I am installing almost all of NIs software library. If you have any favorites let me know.
Edited BFG, should have said SDR in the title.
