Help with simple weldng task
I need some help in the metal shop doing some short welding asks. If anyone is available for help I could you it. I am trying to build a jig for building bass guitars.
It is an “L” bracket with cross braces holding it steady. The parts are cut and ready to assemble.
I can likely help Friday if you haven’t found someone by then.
Thank you Julie,
I found someone to help, but I often need some welding done. I build guitars and need jigs to help me with the builds. Can I ask you for some help again if I need it? I can’t afford much, but I can give you a little money.
