Guys and girls. While I was running old blue, I wanted to do a test run on the Tarkington. When I turned it on, I noticed it jump in the “y”direction. Seen the light cord fell down. I found some tape and taped it back up. It’s running ok now. Just a notice to fix it correctly
How was the cord fastened before? If it fell down. We need to mechanically fasten it so doesn’t happen again. I assume we used VHB tape. I find that VHB tape is great for horizontal surfaces instead of vertical or upside down.
Thanks for for fix, I didn’t know it was coming loose.
It’s the adhesive foam zip tie mounts. I’ve been changing things regularly, so not going for elaborate solutions.
I think the magnetic cable mounts would work better, and they’re easy to reroute as things change.
ooooh. I like magnets
