First project- Process Advice
I’m starting my first project outside of a class. It’s a set of small “tables” that will act as display stands. I attached a sketch of my design, but I’m unsure about two key parts:
What’s the best way to cut a block of wood into 0.5” thickness (or should I just buy 1/2 inch wood?)
What’s the best way to create the feet? I’m a little stumped on how to safely get rounded feet of that size.
Some misc. comments / questions…
  • I’d just get a 1/2” thick wood.
  • When designing bookshelves, which needs to support a bunch of heavy books, it is typically limited to 36” width or otherwise it will sag. What kind of load are you trying to support?
  • I assume your 4x4 in the list of the bottom left means it is 4 feet x 4 feet. If so, the span between your feet is quite large and I’d consider adding intermediate feet to the bottom in the center and on the sides.
  • Are the feet a sphere or a hemisphere - I assume you want hemispheres so they’ll attach to the bottom of your wood. Would you consider: “Rubber Cutting Board Feet with Stainless Washer and Screws, 1/2” Small Black Round Rubber Feet, Non Slip Bumper Pads for Furniture, Electronics & Application,20 Pack” at Amazon.com
  • You can use a router with a 1/4” curved bit to create the round-over radius on top and bottom.
I don’t know if any of this helpful, but maybe talking about what the purpose of your project is would help.
You didn’t supply the diameter of those feet. I’m thinking a hole saw without a pilot or a plug cutter is your best bet (use the drill press.)
If you want 1/2” hardwood common practice is to buy 3/4 rough cut wood, joint it, then plane to the final thickness. The jointer and planer would have been covered in your wood shop safety course.
This is super helpful thank you! And 4x4 is actually 4 inches by 4 inches. Small little items to be displayed. Thanks for the link to the rubber feet! I was thinking hemispheres but the rubber feet may do just fine
Hi @michael.zaino if you want, I’m willing to help/support you with your project. Let me know if this is something you’d be interested in and we can work it out.
Michael
Lathes are great for anything round!
Simple “spindles” or feet can be done with little learning curve.
We have a spindles class that can get you started with that learning if you’d like!
