Hey All, Just joined Makerspace after taking the intro to CNC class a couple weeks ago. Looking forward to getting to know you all. I’ve been learning Fusion and am about 80% done with the design / rendering work. Any advice / thoughts would be appreciated.
Here’s the inspiration shot. It’s a double sided glass built-in cabinet with inset doors.
I have two mirrored built ins. They are 8’ tall and 36" wide. I will be using 3/4" MDF for the cut material
The shelves have a 1/4" tenon joins on the edge strip. I think I need to round these because the mortise side won’t be perfectly square.
I’m cutting half of the door out of 1/2" MDF and the other half out of 1/4" deep piece with room for glass in the middle (see second photo). I will be nailing / gluing them together rather than having to build a ton of mortise and tenon joints for the door. I think this design should be sturdy but I’m not 100% sure.
I have a beveled edge to let the doors close but I still need to add the cut out for the butt hinges.
I’m about ready to start prepping the I think it’s called a cut plan? Then I need to layer in the routing paths. Not really sure how to do either. Anyone have any good instructional videos?
