Just a head’s up, the red light came on and the dust collector was indeed full… emptied it and replaced the bag… but the light is still on. Is there a trick to fixing?
Thanks for checking amd emptying the Dust Collector. Sometimes after emptying it and putting the bag back in, the bag will cause a false ready until it moves out of the way.
I must’ve come in right after you posted, because I saw that and fixed it. You have to make sure the bag is flush against all the sides, especially the back, or it will trigger the detector. Sometimes the bag will blow in if there isn’t a good seal, so make sure the bin is pushed fully in and latched securely too.
