I posted earlier about the Shaper Trace product that is on Kickstarter. I’m making this a separate post because it specifically addresses laser cutting. The Shaper Trace SVG can be used however you want, but if you’ve wrestled with getting an image in a vector format, check out how simple it should be. Start at the 20:00 miniute mark. The laser section is about 6 minutes.
