Did some engraving with Pearl over the weekend, thanks to everyone who got the communication issue solved.
I noticed that my rasters are coming out with “double vision” — edges are duplicated/shifted. It looks almost like I ran it once, then moved the stock very slightly and ran it again, but it was just one pass.
Is this something I did wrong? An alignment issue with the laser?
My best guess is out of focus. Try including a snapshot of the settings or give more information so it can be determined weather is settings, software, or mechanical. Looks like you have an outline on the objects that is darker than the fill which separate a bit when the lens is out of focus. Im going to say too far up or not close enough. Normally if is mechanical (even though focus is mechanical) as in the machine malfunctioning, the circle engraving would be much less consistent. But im not expert, just taking an educated guess.
I found some relevant discussion elsewhere that suggests it could have to do with the nozzle, but I really don’t know enough about the laser to judge. Here was their illustration about that idea:
Plausible, but the side effect of that fault is that the business end of the machine gets super hot very quickly. I’d expect to see cone damage if you ran a whole job with that kind of misalignment.
