I am observing a double vision effect when rastering using Blue. I have ensured I do not have two fills or curves stacked on top of each other in the file and I have moved the object away from the edge. See photo for example
check for loose lens holder
it will only have a problem if “loose” loose. like the screws aren’t screwed down at all and it’s rocking around
that is, those are knurled finger screws and should never be tightened with a tool or even tightened hard by hand. minimal force is all it needs
