Dorian is experiencing an issue where the door will not close completely without excessive force, at which point it makes a loud slamming noise. The problem might be related to the misalignment of the door hinges.
I’m happy to take a look at it but I am not confident working on the machine and don’t want to make the problem worse. Any advice?
Thank you for posting. I have experienced the same issue. I think we need to realign the hinges or elongate the holes to correct the situation. There is a qr code to make a problem report. It will alert everyone that it needs attention
Had both problems last night. Door slightly ajar, laser moves but doesn’t cut, no obvious error messages. Second time, door was slightly ajar again, but the laser did cut. Both times it was the right side that stuck. Lucky for me Other Luke spotted the first problem because I was going through all the settings trying to figure out what I did wrong.
