Hello. I can’t find any domino classes. I thought we could just use it whoops. I’ve got a table top I need to glue up.
As far as I know, the safety/orientation class for the woodshop should have covered the rules for the use of the shop. That’s counting you were listening. I know for a fact the building orientation does cover the fact that if you don’t see a class you need to reach out and ask for one to be scheduled (i was working in the textile room and heard the instructor cover that). Anyway, if your table top is going to be over 1" thick and bigger than two square feet, the strength of a good quality water resistant PVA glue should be sufficient. Now if you dont feel confident aligning the boards, or orienting them the right way, yes you need any help you can get by using, dominoes, dowels, biscuits, tongue and groove, or glue joint router bit. All of the above require specific center alignment. If you decide to go without them, you need good jointed edges(no gaps), grain orientation, and a way to keep them as flat as possible when gluing them. I have made more than a few tables in my life and can tell you all you need is a quality water resistant PVA glue, good smooth gap free edges, and offcourse a good clamping technique. I know there are a lot of YT videos promoting the Domino, Kreg, and others stating you have to make it this or that way. The best proof contradicting that is that you have plenty of antique and very old tables still hanging around that were not made using any of those tools. Ask yourself this question how can you make wood better if youre making a hole in the lumber then filling it with glue and a different kind of wood that expands and contracts at a different rate of most of your top? The tongue and groove and the glue joint router bit are the exception. These two would give you a bigger surface glue joint if done correctly. At the end of the day is your project, your time, and your $$. Good luck!
I think im just going to use pocket holes. It’s my first table so not a big deal. I’ve got a jig and in fact everything is pocket holed on the base of the table aside from the laminated legs. Thanks for the advice! I was going to drop 500 on the Kreg edge. It’s so sweet haha
Hey Adrian, can you email classes at assembly.org and request this class I’ve been requesting it and I’m willing to pay extra if they don’t have all the spots filled but if you and I both need to class, they said that they need four spots but I’m willing to pay for a private class so if we both need it, let’s do this
Got it. Just sent them an email. Will post back if they respond.
Hi Adrian and Anthony, just wanted to make sure these were going to the correct email as we haven’t received anything. The address is classes@asmbly.org.
Whoops. I spelled out “assembly”. I just re-sent it. Hopefully you get it this time.
