Hermes’ build plate is damaged on one side, so you may not want to use that side. If you have small prints, you can plate them elsewhere on the injured side and avoid the area. I’ll assume that the plate will continue to degrade as it is used, which is acceptable. I have another build plate to replace it once it entirely fails.
