Cutting Polycarbonate 1/8'' thick on vertical saw
Hi there,
Can the Vertical Panel Saw be used to cut Polycarboante 1/8" thick ?
thanks!
Sure. The blade probably isn’t ideal but should be perfectly serviceable for plastic. If you go too slowly it’ll melt more than cut. Please be thorough with your cleanup cleanup - plastic dust can float pretty far.
