Wondering if anyone has already figured out a technique for making a countersunk screw hole with the lasers.
I’m working with acrylic, so I think it’d be possible to make a set of concentric rings around my cut hole with varying power settings to get progressively deeper and thus approximate a countersink.
I think it should be workable, but you’ll have to experiment a bit.
You could either do radial gradients and raster them, or plot a decreasing-radius spiral (so more passes overlap the closer you get to the hole). I suspect the spiral would be faster but trickier to fine-tune for shape.
