Did the CNC rotary get cleared for service, and is a class required? This thread seems to have dribbled out with no conclusion: 4th axis rotary - #75 by pearlgreymusic
Side note: can we dial down or disable some of the nanny features in here? “CNC Rotary” is a perfectly valid title, but I’m informed it must be at least 15 characters.
The rotary needs some help to finish. The 1st test had some issues. The diameter of the cylinder was not the correct size. The cut was not the full 360 deg. I believe it was 270 deg. We should get some minds together to help get it into service.
For now, yes. Autodesk unfortunately doesn’t offer a discounted version of that advanced machining add-on for Fusion, and I doubt we’ll ever be able to justify a multi-thousands-per-year subscription price. We can get Inventor at a reasonable cost, but it sounds annoying to have to learn a different Autodesk package to do multi-axis. We might consider buying Aspire if there’s a good argument to be made for it.
