The other day in the shop someone mentioned that the CNC was acting weird and cutting from the opposite end. He talked through all the things he checked and I was just as baffled. I used the CNC the following day (I believe) and everything was fine. However, today the same issues he was having I was experiencing. I homed everything, set all the axis points to zero, triple checked that I wasnt using an offset in the file but the CNC would seem to start cutting the opposite end. It even showed on the computer screen that the board was lined up correctly when the spindle was moved with the wand.
I don’t have much experience on the CNC intricacies - what could I be missing? Is there a setting that keeps getting selected that causes this? How else can I reset it? Any help is appreciated!
Also, I was having issues with the 1/4 collet - but seemed to be slipping a little
