Anyone looking for a generator?
This Champion 3100W Inverter generator has been modified to run off of an external marine tank. The external tank and hose is included, along with another 5 gallon gas can. Hooked up to the 6 gallon tank, it can run for over 24 hours. It can also still run on the internal tank, but only for about 6-8 hours.
I keep the oil changed, and have only run Royal Purple full synthetic oil in it. I have a spare fuel line filter, spare fuel fittings for external fuel line, and a spare pump. The pump has never had to be changed 7 years, but I kept a spare because it’s not going to fail at home.
Pinellas sells the mod kits for $277 - here - Champion 3100 Extended Run Time Fuel Kit with Internal fuel pump
My fuel modification includes a right angle fitting to make the fuel inlet stay close to the generator, making it safer to load and travel with. FWIW, the fuel connection is on the air intake side, not the exhaust side.
Included:
Champion 3100W Inverter generator, modified with external fuel inlet
6 gallon marine fuel tank
Fuel hose with priming pump
Spare fittings, filters, pumps
5 Gallon plastic no vapor gas can
