Any recommendations on cabinetry design software? I have several large client projects coming up, one doing a full kitchen cabinet build and the other a custom shed pub installation with bar and furniture. I typically do my design work in Fusion 360, but I’m wondering what other options are out there. I’d like to have the ability to export to vcarve as I want to be able to cut panels on the cnc. This is for my business so I don’t mind spending money, however I don’t have the budget for a system in the $thousands.
maybe jennifer might have a suggestion. @JennChilds
Are you having issues with Fusion CAM?
Look into Mozaik. It’s affordable ($125/mo for the CNC version). Really easy to use and you get to specify your construction method (dadoes, etc). Comes with a library of cabinets and then you can create your own.
Here’s an article about a small shop for with Mozaik - https://www.fdmc-online.com/fdmc/november_2018/MobilePagedReplica.action?pm=1&folio=21#pg24
I’ve been exporting from Fusion to Vcarve for my CNC work as I understand there is some sort of gcode issue with Fusion and Asmbly’s cnc, although I have not yet taken the time to learn what it is. Fusion is great and I am proficient with it, but it can be somewhat time consuming and so I am looking at faster software options that are designed specifically for cabinetry.
Thanks! I’ll check out Mozaik.
