There are multiple box generators out there, both web-based and as Inkscape plugins. I’m wondering what’s been your experience with using the output files on our lasers, if you found some better than others, etc. I have zero experience using any of these tools so any guidance is welcome.
My own needs are fairly simple: looking to make some lidded boxes, about 8"x10"x3". I’d like to use chipboard about 1/16" plywood about 1/8" thick, if that makes a difference
I second boxes.py
I have made several boxes, trays, hold downs and more from there. Some of the designs take a little trial and error, simply to understand the input structure, in the generator. There are tons of designs, many of which are not well documented. But the end build results have always been great. The nice thing is that you can do most of your debugging and dimension trials in the output files. You don’t have to burn your material until you are happy with the design.
I used boxes.py to make the holders under the community bulletin boards in the lobby (made modifcations to create the design, but started from their generated file). I think @tomthm might also use it for his heart boxes.
That’s correct. An important parameter is the offset (can’t remember if it’s called that) that allows the pieces to fit together snugly, but without requiring force. I think I use .05. And I also think that must be mm because it sizes in metric. When I’m at a computer I’ll check.
