This is a safety primer about bench grinders and especially Aluminum. I still see aluminum being ground into the bench grinder. It is dangerous.
Thanks, Joe. These are great. I like the drawings a lot. It takes some effort to make a tech manual fun!
I have a little safety handout from the Woodcraft class I was going to hang near the grinders as well, after laminating, I can laminate your pamphlet too if you have hard copies to share?
link to pdf version of that same grinding wheel safety doc.
