Tonight, I cut some Aluminum diamond plate for @JOSEGAYTAN. The IQ cut it beautifully. 75 ipm, .0235 depth of cut, 18,000 rpm single flute .25in bit.
After it was cut out, he took it to the lasers and used Cera Coating to add a great black outline.
Fun project to help out on, and the results are great.
mgmoore
(Ethan Moore)
2
I am really shocked that that RPM worked out. On the mill, I’d use 1/10 of that speed.
JoeN
(Joe Ngo)
3
you can use psuedo high speed machining techniques to cut fast
In my limited experience, the higher rpm’s work with the higher feed rates. Ive done some at slower speeds and rpms and didnt have as much success.
Hoosier
(David Henderson)
5
I’ll be in tomorrow to try some aluminum on the Swift. Just simple test pieces but things I need.
LoboFPV
(Wolf Dilworth )
6
Thank you, James
That is good to know, real world usable feeds and speeds. Great looking project.
-Wolf
