Anyone have experience in shaping acrylic? I need to put a subtle curve into some pieces and I’m trying to devise the best way to do so. So far I think my best idea would be to route said curve into a block of wood and then heat the acrylic and press it into the groove then let it cool.
That’s the only technique I’ve used. Buy enough material to practice on – I still have trouble getting acrylic soft enough to bend without blistering it
I have a toaster oven that I use to bend small objects. I also found the blister point. I ran the temp lower on the next test and was able to bend it. @Devmani Let me know if you want to borrow the toaster oven?
I have no experience in this, but do y’all know if moist vs dry is better or worse? Just curious if that might help. You could add a pan of water in a lower shelf of the toaster if it would be good. Could be a good experiment if no one knows off hand.
