6/2/2026 21:35:33 - 3D Printing - Elegoo Resin Printer - Dione
Problem Type: Equipment
Workspace: 3D Printing
Asset: Elegoo Resin Printer - Dione
Summary: resin spill under FEP / on screen
Additional Info: After an aborted print I inexplicably decided to clean the tank. While doing so I jostled the funnel nozzle without noticing and spilled some resin. I then stupidly put the tank back on the screen to try to address the spill.
When I returned to the tank, I tried to clean the screen and under the FEP thoroughly and gently.
However it looked like at least one drop of resin went into the crack around the screen!
So sorry! I will probably never touch the resin stuff again, sheesh.
Thanks for the report. Cleaning the tank if there might be any bits left floating from a failed print is the right call. Resin spills happen to everyone. We’ll get it cleaned up.
Looks like there was no harm done.
