12/18/2025 11:37:24 - Metal Shop - Tormach PCNC 1100
Problem Type: Cleaning
Workspace: Metal Shop
Asset: Tormach PCNC 1100
Summary: Chips not cleaned up
Additional Info: Most of the machine is very well cleaned, but there are a bunch of chips at the bottom of the machine
Please vacuum out the chips from the bottom of the machine. You may need to blow the coolant to the drain with the air gun to avoid vacuuming up too much coolant Please also make sure the drain is not clogged with chips
