Problem Type: Equipment
Workspace: Woodshop
Asset: Belt Sander - Large 36" Powermatic
Summary: The machine stopped running
Additional Info: Possibly airflow related? The belt was off track when I opened it, and there was a lot of sawdust inside.
The initia thickness setting is entirely adjustable — release the jamb nuts then adjust the screw up or down slightly. It’s 20 threads per inch, so it’s only a tenth of a turn to change it by 0.005”. Then carefully retighten the jamb nuts.
(I’m going to replace the small bolt with a sturdier 1/2-20 bolt and proper top and bottom jamb nuts at some point. That should make it a bit easier to adjust.)
Did anyone adjust the thickness setting? Because I had it set to barely make contact with the board. If it’s stiill drifting, then we have another problem to address with that mechanism.
