11/14/25 12:59PM Woodshop - Belt Sander - Large 36" Powermatic
Issue type: Equipment Problem
Area: Woodshop
Equipment: Belt Sander - Large 36" Powermatic
Summary: Res tag, limit switch not working
Additional Info: The left side limit switch is not switching. Some sandpaper started running off and sending some Sparks from rubbing on components. Components. The components all look fine and there are no smoldering bits of dust. Drew, a new member, is helping to fix the limit switch so that it functions properly.
Someone has started working on this.
