08/28/25 02:40PM 3D Printing - Prusa XL
Issue type: Equipment Problem
Area: 3D Printing
Equipment: Prusa XL
Summary: Tool Change error on 3rd head
Additional Info: Print failed after the ~2nd layer with this error. Left a lot of stringy filament of that color over the part. Just restarted the print after moving filament from tool head 3 to 5
Green filament was on head 3
When the XL put that tool back on the holder, did I seem visibly mis-aligned?
When the error occurred the 3rd head was over the bed. When I moved the filament to 5, it seemed to put 3 back without misaligning it.
Hmm. Weird. You didn’t happen to take a picture of the error screen, did you? Or somehow capture the error number?
No, I forgot to. Will snap a pic next time if it comes up.
Thanks. We’ve seen tool changer problems before when trying to dock/undock, and it’s usually just a matter of recalibrating where the printer thinks each dock is. I haven’t seen a tool changer error in midflight. I wonder if the tool came loose in the moving part.
I ran a print this evening that had a lot of changes to/from tool 3, and didn’t see any problems. I’m going to call this “fixed”. Please open a new report if you see this problem again.
