Issue type: Equipment Problem Area: CNC Equipment: Laguna Swift CNC 5x10 Summary: Had a bit drop issue Additional Info: But dropped on cut and cut into spoil board 1/4”
What can cause a bit drop issue? I’m asking because I don’t know if this is something that can just happen and is unfortunate when it does. If it is a result of not tightening hard enough, doing something funky with bitspeeds, A worn out collet, I’m just not sure which is why I ask.
Thumbs up for the mea culpa problem report. That should be the standard behavior, so that stewards don’t have to play detective to learn who to talk to about an incident.
