Issue type: Cleaning Problem
Area: Woodshop
Equipment: Jointer 12" - Laguna JX/12 Sheartec
Summary: Dust collection is not working
Additional Info: Tried disconnecting hose to check for clogs, none apparent. Stuck a shop vac hose to see if anything needed to be dislodged and it still started spitting up chips when I turned it back on. The jointer is jointing it’s just going to be a mess. I’m guessing there is something closer to the cutter head that’s blocked up
