07/09/25 06:02PM Woodshop - 24" Resaw Band Saw - Grizzly G0569
Issue type: Equipment Problem
Area: Woodshop
Equipment: 24" Resaw Band Saw - Grizzly G0569
Summary: Blade
Additional Info: Blade needs replacement. Weld is about to fail.
Parts have been ordered for this.
Any update on this ? Was it just the blade that is needed for the saw to be operational ?
Wheels cleaned, insides cleaned, Blade put on. We have one more backup.
These are pricy blades so please be aware of the machine when you use it. Check alignments regularly and ensure the machine is in correct condition.
If you see something say something!
If you put a lot of use into this machine, consider assisting with upkeep of it, cleaning the insides after a heavy use, or donating to help replace damaged blades. Ideally each one lasts a few months.
If anything, at least please drop a problem report if there are future issues.
@Jeffmc thank you for offering a hand.
We have an extra blade in the stewards closet in case this is needed in the near future.
