07/01/25 11:23AM Woodshop - Table Saw 2 - Sawstop
Issue type: Equipment Problem
Area: Woodshop
Equipment: Table Saw 2 - Sawstop
Summary: No power
Additional Info: It’s plugged in and breakers look ok
Is the main power switch off? It’s on the side of the saw near the bottom?
I saw this post as I’m sitting in the shop, so I thought I’d check it out. You are correct, sir. I turned the big red switch, and it came on.
Thank you!
