Issue type: Equipment Problem Area: CNC Equipment: Laguna Small CNC Summary: Small CNC stopped reading usb drive Additional Info: I loaded a file and program ran fine. Tried to load another file and it took a very long time ‘reading’ the drive, and then eventually came back with a message saying nothing was there. Tried several drives, none of them could be read.
Rebotting did fix it, and I ran subsequent jobs after this with a problem. However, you lose the work orgin by rebooting. Due to how it was programmed, it was not possible to re-zero in this instance (machined away). So, I was not able to finish that part.
IIRC, others have reported this behavior as well; this is not the first time it happened.
Workspace coordinates persist through a reboot, but I advice making sure you’re in the same workspace and that the z zero hasn’t changed (it’s rare that z changes, but potentially catastrophic if it does)
