06/08/25 09:59PM CNC - Laguna Small CNC
Issue type: Equipment Problem
Area: CNC
Equipment: Laguna Small CNC
Summary: Spindle frequency won’t exceed 50
Additional Info: When toggling the spindle on/off or running gcode the frequency is over ridden and the machine spins too slow to cut
I can confirm this is still an issue. The spindle display says 300Hz until a job is started, then it locks onto 50hz and won’t exceed. I tried troubleshooting a little bit but with no luck
Thanks @gordoa40. Red tagged until we figure it out.
I initially reported this. I tried to debug and couldn’t figure it out. I’m very interested in the solution/ debugging process.
@jamesfreeman figured out the issue and I was able to use it successfully. Red tag can be removed.
What was the problem?
I believe the back up software we recently loaded had the preset spindle speeds settings. I think this caused the VFD to default to the low settings. We removed the wires from the VFD and it went back to normal.
I noticed while teaching last night that the rapids on the small CNC were very slow. Could that be related?
Most likely
