04/07/25 09:15AM Woodshop - Belt Sander - Large 36" Powermatic
Issue Type: Equipment Problem
Area: Woodshop
Equipment: Belt Sander - Large 36" Powermatic
Summary: conveyor belt stops
Additional Info: conveyor belt stops unexpectedly and randomly. It often did it right after an adjustment up was made . The motor is good (stops when conveyor does). It restarts no problem by pushing the conveyor button. I will call powermatic support to ask them as well. No alarms etc were triggered - best guess is there is a connection starting to go bad behind the button where the wire connects . I can take a look at it tomorrow. I don’t see an issue other than being aware so that you can push the conveyor start button if you see it stop - if stopped it will sand in that one spot and potentially ruin sand a trough in your work.
