Lulzbot Error:MINTEMP
Tried changing the filament this morning on the lulzbot, got disconnected from Octoprint with “State: Offline after error
Tried cycling power a few times, no luck.
Dunno for Lulzbot but that error typically means the heat bed or Hotend has dropped below a set configured temp and the safety kicked in. After a reset and the error still present it may mean a thermistor is broken.
The thermistor may be bad. I’ll check it out next time I’m in the shop. If you could please place a defective sticker on the printer.
