Haha okay, because it was specifically requested, here’s an iron fist. Tough love incoming:
None of this technical discussion makes any difference whatsoever to the actual problem, because the actual problem is not a technical problem. You can look at that room for 20 seconds and tell what the actual problems might be, but here’s an example list of things which the problem definitely isn’t:
- The presence or absence of advanced or obscure oscilloscope capabilities
- A soldering iron with a slightly longer time-constant but which is functioning perfectly well
- Jacket polymer selection for the spool of wire occasionally used for rework
And here’s an example list of some things about the EE lab which you might fairly conclude contribute to the actual problem:
- Stuffed with junk, rather dirty and cluttered
- Not one single functioning piece of basic equipment
- No coherent vision for the space, minimal ownership, minimal patronage
- A degree of inertia which apparently approaches infinite
The proposal I put together was meant to try to address those problems as well as they can possibly be addressed within the $5k budget figure I was told. My recommendations were optimized to be easily executable with minimal friction because that’s what seems to be needed. They aren’t meant to be answers to the Asmbly EE lab fashion quiz, and now we need to figure out how correct those answers are.
No prospective user of this lab will have their problem-solving experience improved or worsened in the slightest depending on which model of brand new, perfectly functioning multimeter is available to them. I understand the desire to optimize, but please don’t get so bogged down discussing the difference between the 97% solution and the 98% solution that the space remains stuck in its present 4% solution state forever.
I would try to focus on the things which seem to be the actual problems, and see what kind of shapes the solutions to those problems might take.
