I was using the planer for an end grain cutting board. After sending it through a couple passes, the board got stuck and the motor switched off. Now the planer won’t turn on.
I put a defective sticker on it. Also found a nut on the bed of the planer, perhaps that has something to do with it, really not sure though.
I’m really sorry! Hope this isn’t a huge ordeal to fix.
I was up there yesterday and had to do 2 quick passes on the planer for my CNC job. At the time I didn’t think too much of it but on the first pass I also struggled to get my board to feed through (especially in the middle) as well. Came out with yellow streaking on it which seemed strange but I figured that was from someone else’s surfacing. Second pass seemed to pass through just fine and yellow streaking was gone so I thought it was possible user error. But now that you mentioned it getting completely stuck I’m thinking something might be wrong (feeder issue?) not sure how to trouble shoot and help fix but I’d be glad to help in whatever way needed.
I wonder if someone made adjustments to the planer that caused some issues with the blades or auto feeder (adjusting cutting while running, adjusting blades incorrectly etc)
I thought the general woodworking consensus was to never run end-grain through a planer due to the risk of catastrophic failure? The concern being that the knives can catch on the end grain causing the board to split in two along the grain (not an issue when working with the grain), potentially breaking the knives and/or planer and potentially launching out the broken-off bits.
It would also be fairly simple to build a jig and use a router with a fly cutter bit. There is a new DeWalt corded router in the shop that would be more than capable.
Using the CNC router with a surfacing bit can flatten out an end grain cutting board. He is recommending that as an alternative to the planer in the video there. The drum sander will make slow progress at flattening- it’s best to do the bulk on the CNC and finish with the fine sanding on the drum sander.
There is a router sled sitting above the large sheet storage. I’ve never used it, so I’m not sure which router is was built for, but may save some time in making the jig.
CNC or router. Both can work. It’s just a matter of what you’re more comfortable with, or are able to use. Thanks @jamesfreeman for pointing out the sled. I’ll check it out this weekend. I have a cross grain slice of pecan I need to flatten part of before carving.
