Air assist compressor is popping the breaker
@J-LoM - wanted to make sure you saw this
Also @Ryanpearson @JCicolani and @DannyADL
We’ll get another compressor in there today
Excellent, thanks!
@dannym I still can’t cut 6mm baltic birch on Tarkin. Air Assist seems fine, but I think power may be more reduced than you had hoped. I went all the way down to 4mm/s feed rate at 100% power and it only partially cut through – and made a char of my ply at that slow speed.
Dorian can cut the same ply at 10mm/s at the moment.
Tarkin cut 3mm baltic birch at ~20mm/s speed, but even that was a bit iffy.
If you are still available to take another look at Tarkin, I’d really appreciate it since I had planned to cut a large amount of 6mm tonight and someone else has Dorian booked in an hour.
I updated the thread title here to represent the latest status as I understand it. As of late last night, Tarkin was operating but at much reduced power. It might be able to cut ideal 1/4" / 6mm baltic birch. Fine with 3mm and such, as well as basic surface vector/raster runs.
I’m not 100% sure if anything else has changed since then today.
@dannym Any updates or further thoughts to add, please?
Best to just keep it red-tagged for now. I see what I need to do but I’m seriously overwhelmed right now. I can’t do it today.
Bummer, but thanks for the status update. I changed this thread title again to reflect that.
FYI @Jalen since I see you have it booked later tonight and I’m guessing you might have made that booking thinking it was fixed.
Is this an issue someone can look at for you @dannym?
Will be red-tagged the rest of today. ETA for repairs is Sunday.
Power issues resolved, but still red-tagged due to a coolant leak.
I’m new and unfamiliar with this platform… but I do have Tarkin reserved for later this evening… is it still redtagged?
Yes it is. It needs to be red-tagged one more day.
It’s fixed and performing really well, but I didn’t have time to fully test it
