I have been trying to cut 3mm BB. I finally got it to cut through at 50 mm/s and 100% power. There was a lot of soot on the lens before I started. During a long cut, it stopped cutting through and will now barely mark the sheet. Tried cleaning the lens again, no good.
Red tag it please
I left the panel I started, on the bed of the laser.
It is really important that if a laser isn’t cutting as expected, don’t just slow it down and try to force it. The energy is going somewhere, and it’s a lot of energy.
Please, do not leave without red-tagging it. Just leaving it for the next user is opening it up to more damage.
I left the panel there for you to look at…
The air assist compressor had problems. How long do they last? About this long, I guess. That’s needed to keep the lens clean and cool so it punched a hole right through the lens and skunked up the #3 mirror. Well, that happens.
I’ll be back up later with the stuff to fix this. It’s actually just the power cable on the compressor, but I think I can just move Dorian’s compressor to it now that it’s on the air system. It won’t take long to get an air valve and pressure sensor for Tarkin anyhow.
Thank you Danny!
-Abe
Fixed, cut fine at 120mm/s!
