The bandsaw with the skinnier blade. It was red-tagged when I was last in on Wednesday. Still red-tagged? Thanks!
The bearings have arrived. I was planning on installing the bearings this weekend, but something came up. I will work on it Tuesday.
The bandsaw is back in business. The bearings have been replaced. The saw is cutting pretty straight. The cooling blocks are worn in a little weird. The cooling blocks being worn is allowing the blade to move more than it should. If you pay attention to your cut line. It is easy to compensate.
Thank you very much!
