Won’t be able to make this one, but would be awesome if you were able to post before and after pics @jamesfreeman. If you’re surfacing both the top and bottom of the material, one trick I very recently learned was to make tiny pencil markings showing the corners of the material in the spoil board. That way when you flip it over you don’t need to reset your x and y origin, only the z height.
Looking forward to seeing what this slab slayer can do, especially since we talked about it so much last CNC meetup!
We started by flattening a cutting board @Allzman brought in.
Then moved on to a mesquite slab. The slab was cut at 1/8" depth and 400 ipm, with the bit spinning at 15k.
The results were amazing. Both pieces had a finish ready result. I havent post processed the mesquite yet, but suspect it will take very little sanding with a high grit.
Art has finished sanded the cutting board, and I believe it took very little work.
