Seeking motor expert for 220VAC to 110VAC conversion
I have a diamond wet stone cutting miter saw with table that runs on 220VAC/50Hz from Europe. I need to convert it to run on 110VAC/60Hz power. Seeking someone with power electronics expertise to help me design and implement this conversion as a paid gig. Need to figure out the motor driver and see where a new 110VAC source can be added. Thanks, Gaurav Goel, 512-771-0253
Likely an AC induction motor and likely has a wiring option for 120 or 240v operation. If you can provide a photo of the motor nameplate and inside the cavity where the power cable goes into the motor I may be able to tell you how to adjust the wiring to get 120v operation.
If you can’t find that info send me make, model and year of the machine I may may be able to find a service manual from a friend.
Clay
Thanks, I’m guessing it’s a DIN standard type. Gaurav
Hi Clay, here is the motor badge and pics of the wiring box. It has a start capacitor on a first start position to turn on and then a second run position on the
