Scroll Saw?
Does anyone know if the scroll saw is working and do I need to supply blades?
I haven’t seen any problem reports about it recently. IIRC, yes you have to supply blades.
Thanks Evan!
He is correct! It is up for use, no class required. If you or anyone reading. This is unfamiliar with the operations, please do some research and look up videos. Ask if you need assistance.
BYOB! Bring your own blade
I would recommend a skip tooth blade if you’re going to be purchasing some. Rockwell and WoodCraft carry them.
Good to know. Thank you, Michael!
