Sandblasting larger objects?
is there a way to sandblast an object that won’t fit other sandblast thing in the metal shop? thanks.
How large is your object?
thanks a lot for this Joe. i should have mentioned this. so approx 12 x 12 x 28". its made of 1 1/4" tube and is the lower part of a motorcycle frame. then plan is to add some “feet” so i can mount an engine in it and work on the engine.
You can blast it at home with an abrasive blaster. I don’t know if you have an air compressor that can keep up. I would wear a really good respirator.
I have a larger unit at my shop if you want to attempt it here. The dimensions are a little bit tight for the 28" side.
