PLA filament getting stuck in ABS—something about the spool or filament?
I have a spool of SUNLU Matte PLA I’ve successfully used on Asmbly’s Bambu P1S printers in the past. Recently, I’ve had the same filament immediately get stuck when the ABS tries to load the first few inches.
Since I’ve had the same problem on multiple printers, what are some things about the spool or filament that might be causing this?
I am suspicious that the increased length of the AMS tubes since we routed them below the printers is causing some of this problem. We intend to shorten them, but we haven’t gotten around to doing so. The theory behind this is that there’s some friction between the filament and the tube, so a longer tube means the motors need to work harder. This would be especially true for matte filament because it’s inherently less smooth. However, if it’s getting stuck in the first few inches out of the AMS, that doesn’t seem as likely.
Have you cut a good diagonal edge at the start of the filament?
If you need to remove filament from the AMS, and the AMS is not working, you can disconnect the tube from the back of the AMS and pull the filament out manually. If you’re pulling from the AMS direction, you’ll need to snip the filament, or more will just spool out. Here’s how to remove the tube: https://www.youtube.com/shorts/19y66xk-pfc
I saw the same problem with the new longer tubes. I pushed the filament till it went past the filament sensor and into the print head. I was helping Shane
Thanks for the link, Aneel! I’ll try again later and see if a good diagonal edge at the start of the filament helps fight some of that initial drag in the feeder tube.
I wonder if the AMS is feeding to a certain amount which is not close the print head. The initial feed was not even close from what I observed the other day.
It only seems to be feeding in a few inches of filament before it stops/holds on. I can check later this afternoon to see if the filament is even leaving the ABS.
I’ll try to shorten the tubes tomorrow, if nobody beats me to it. We did see a problem recently where some white filament had broken in the tube and it looked like the tube was empty, but it was blocked.
I’ve shortened each of the AMS tubes by at least a foot. My first AMS print on Athena, Bastet, and Chantico worked without complaint, including with both matte and silk PLAs (on different printers). @Winnermint, would you mind trying to load your Matte PLA again and see if the shorter tubes help?
Yes! I’ll book some time this weekend to test the matte PLA again on the shorter tubes.
Loaded the Matte PLA in to Bastet’s ABS (cut a good diagonal edge for good measure), loaded with no issue, and successfully the first layer. Fingers crossed for the rest of the print!
